You stand in front of the shelf in the toy store or scroll through an online shop and see countless boxes with airplanes, cars and ships. There is a large number from 1 to 5 on every packaging. This is exactly where many people ask themselves: What does the Revell Level System mean in practice for model building beginners? A bad purchase at this point often leads to frustration because tiny parts break off or the liquid adhesive smears on the window. If you want to understand the Revell Level System for model building beginners, you have come to the right place.
This guide defines selection criteria for Revell entry-level kits, specifies the basic tools and explains the assembly steps. We take a close look at the different levels of difficulty so that you can avoid frustration and have fun starting your new hobby.
What does the Revell Level System mean in detail for model building beginners?
The Revell Level System is a five-level classification that divides kits according to their level of difficulty and the level of craftsmanship required. According to the official information from Revell (2025), this labeling helps hobbyists of all ages immediately find the exact model that suits them. In contrast to unmarked kits, this system offers clear orientation from very simple plug-in models (Level 1) to highly complex professional projects (Level 5).
Around 1,949 user experiences on Testbericht.de (2025) confirm that this classification avoids frustration and gradually promotes one's own skills. For you this means: You don't accidentally start with a 659-piece battleship, but rather choose a box that corresponds to your current skill level. The question “What does the Revell Level System mean for model building beginners?” The answer is simple: It is your personal roadmap for a stress-free introduction to this fascinating hobby.
- Level 1: Plug-in kits without gluing or painting
- Level 2: Simple kits (approx. 20-50 parts) for gluing
- Level 3: Medium weight models with detailed painting
- Level 4: Sophisticated models with many individual parts
- Level 5: Complex kits for absolute experts
Which Revell Level System model is best for beginners?
A Revell kit for beginners consists of 20 to 50 plastic parts that are assembled without special tools. If you are wondering what the Revell Level System means in practice for model building beginners, first look only at levels 1 and 2. These models are recommended for absolute beginners as they guarantee quick success. You don't need any in-depth knowledge of putty or fine airbrush techniques.
Junior kits: Level 1 for a very early start
The Junior Kit from Revell is a special level 1 plug-in system that requires no gluing or painting. A current report from the car media portal (2025) shows that the traditional company is specifically targeting car-loving young people aged four and over with these kits. This is the perfect introduction to the Revell Level System for model building beginners.
The colored components are securely connected by simply plugging them together. Decoration is easy using the included stickers, so-called decals. So even the little ones can use it straight away Model making start without having to wait for long drying times.
The easy-click system at level 2
The Easy-Click system enables detailed models to be built for ages 10 and up thanks to a clever plug-in mechanism without plastic glue. In contrast to classic kits, Level 2 offers the great advantage that the parts are already colored in the basic colors. You simply put them together and get an amazingly stable result - an important part of the Revell Level System for model building beginners.
According to Revell (2025), this method guarantees quick success. If you want, you can use the included stickers or paint the model for a more realistic look. This is the perfect transition from just a toy to a serious hobby.
Tools for the Revell Level System: What do model building beginners need?
The basic equipment for aspiring model makers consists of a side cutter, fine files, plastic glue and a small selection of basic colors. In the Revell Level System, assembling models from level 3 requires the use of specific tools. According to Revell experts (2025), a budget of around 50 to 80 euros is completely sufficient to get off to a really good start.
A cutting mat set and good, daylight-like lighting significantly improve the quality of work. Very important: Never separate the components from the cast branch by twisting or breaking them, but always use side cutters. This way you prevent ugly white breaks in the plastic.
Which model building glue is best?
Revell Contacta Professional is a liquid plastic adhesive that permanently welds the plastic parts together using a minimal melting effect. This glue has a very fine metal cannula with which you can apply the liquid precisely.
A very common mistake for beginners is using too much glue. Always apply it extremely sparingly and let it set for a short time. The complete drying time is usually several hours, but the parts often stick after about 10 to 15 minutes. If a part breaks off while assembling a model, you can usually easily fix it again with a tiny drop of this glue.
Level 3 in the Revell Level System: Too difficult for model building beginners?
A Level 3 kit requires basic gluing and detailed painting according to instructions. Experienced model makers advise on the Revell website (2025) to only start at level 3 if you have already gained initial experience with levels 1 or 2. These models have significantly more parts and require precision when removing and gluing.
For absolute newbies, this can quickly seem overwhelming. According to Testbericht.de (2025), medium-heavy kits are aimed at hobbyists aged 12 and over. If you have understood the Revell level system for model building beginners, you know: Start with level 2 to get a feel for the material and only then switch to level 3. Complex kits of levels 4 and 5, such as a 659-part ship for people aged 15 and over (Idealo, 2026), are better saved for next year. This is exactly where the Revell Level System for model building beginners shows its strengths: It protects you from being overwhelmed.
How do you paint Revell models correctly and without streaks?
A well-planned coloring sequence ensures a clean end result and prevents hidden areas from remaining unpainted later. According to Idealo (2026), the carefully considered sequence of painting is the be-all and end-all when completing a model. The packaging colors show you basic painting for quick results, which is particularly helpful for model building beginners using the Revell Level System.
However, the construction instructions contain detailed color recommendations for authentic, true-to-scale replicas. You should often paint smaller parts on the sprue before cutting them out. Basic colors such as black, white and gray are sufficient to start with.
Revell Aqua Color vs. Email Color
In contrast to solvent-based enamel paints, Revell Aqua Color paints are water-based and almost odorless. For beginners in the Revell Level System for model building beginners, the Aqua Color colors are a much better choice. They dry extremely quickly - they can often be painted over within 20 to 30 minutes.
You can also simply wash your brushes with warm tap water after work. To paint with a brush without streaks, dilute the paint on a palette with a little water. Apply two to three very thin coats rather than one thick coat that obscures fine engravings and details of the model.
Attach water slide decals correctly
Applying decals is a process that transfers fine details such as labels or warnings to the painted model surface. Cut out the desired motif exactly with small scissors and place it in lukewarm water for about 10 to 20 seconds.
As soon as the image can be removed from the backing paper, carefully push it directly onto the model with a damp brush. Then gently blot the excess water with a soft paper towel and allow it to dry completely.
Conclusion: Make optimal use of the Revell Level System for model building beginners
The Revell Level System enables a structured and frustration-free entry into the exciting world of miniature models. Now you know exactly what the Revell Level System means for model building beginners and how to choose your very first kit correctly. Start relaxed with level 1 or 2, get the basic tools and, above all, take your time with the painting.
The patience definitely pays off when you hold your first finished and clean model in your hands. Are you interested in starting your first project? Take a look at the current entry-level models and start your new hobby today with a suitable easy-click kit from the Revell Level System for model building beginners.
Frequently Asked Questions (FAQ)
Do you have to paint Revell models before or after assembly?
This depends heavily on the respective component. It is often better to paint large body parts or fuselage halves after rough assembly. You have to paint very small details, like the inside of a cockpit, before you glue them into the model, as you won't be able to reach them with a brush later.
Is it worth buying a complete Revell starter set?
Yes, starter sets (often declared as “model sets”) are ideal for the very first attempt. In addition to the kit, they already contain the most important Aqua Color colors, a double-sided brush and the matching Contacta Professional glue. This way you don't have to buy everything individually.
Are Revell RC models also divided into levels?
Yes, the system also helps you with remote-controlled cars. According to Revell (2025), RC beginners should start with ready-to-run models (levels 1-2). These are suitable for ages 8 and up. Kit RC models, on the other hand, require previous craftsmanship experience.
What do the scales like 1:24 or 1:350 mean?
The scale indicates how much the original was reduced for the model. At 1:24 the model is 24 times smaller than the real vehicle (typical for cars). A scale of 1:350 means a 350x reduction and is often used for huge originals such as battleships.
Sources
- Revell Level System – model building according to level of difficulty (Revell, 2025)
- Model Making > Model Making Level 3-5 > Model Sets (Revell, 2025)
- Tried out: Junior kit from Revell – award-winning entry (Auto-Medienportal, 2025)
- Revell model kit experiences: Top ratings (Testbericht.de, 2025)
- Revell model kit at the best price (Idealo, 2026)
